Hello There!
As the title says i am trying to get my esp 8266 nodemcu v3 to work with my cync extension led strip.
Heres the backstory; a few years back i accidentaly bought led extensions froma closing store and cant return (i know im dumb for that i should have read it more clearly (was in a rush)) so now im stuck with them.
So baiscally im pretty sure i didnt connect it all right and i cant control the led strips, so if your able to help with the settings and connections greatly appreciated!
I installed wled using the website, and heres the pinout:
There are 5 pins on the LED strip: 12v in, and green, red, blue, and white which are all negative.
12v Positive/negative connected to mosfets positive/negative (they are in the right spots)
Then the 12v positive out is connected to the led strip 12 in.
Afterwards each individule colour is connected tp the negative out on the mosfets
(there are 4 total mosfets)
Then the grounds on each mosfets are connected to the grounds of the esp board
afterwards there are pwm/trig pins to connect to the board which i dont know which ones
Thanks for all the help i get!
