I’m using micro controler AZDelivery NodeMCU Lolin V3-modul ESP8266 ESP-12F and LED strip YUNBO WS2812B from Amazon.
As I,m new to this I started to test in September last year and it was a straight forward operation, no problem at all. Since then I have been working on and made a few built in projects with good result.
Last week I was attemting to build some more but now I can’t get them lit up.
I have installed WLED 0.14.2-b1 to three different boards and attached two different LED strips to them.
The only thing that happens is that I can connect via wifi and get the UI and the blue LED on the board is lit. If I click the power switch button in the app or computer the blue LED turns off. Two different power supplies tested as well.
Previously when I connected the LED to the board and connected the board to power the LED immidiatly lights up with orange color but now after three different boards I have no light. I can’t figure out what the problem is! Could the whole batch of 5 circuit boards be broken?
If I messure the 5V output I get about 0,7V. Seems like a strange number to me, what voltage is normal?
Regards,
Tomas
