Hello again,
Now I try to add the usermod “battery” to WLED.
The readme says:
Installation
define USERMOD_BATTERY in wled00/my_config.h
My “wled00/my_config.h” looks now:
#pragma once
* Welcome!
* You can use the file "my_config.h" to make changes to the way WLED is compiled!
* It is possible to enable and disable certain features as well as set defaults for some runtime changeable settings.
* How to use:
* PlatformIO: Just compile the unmodified code once! The file "my_config.h" will be generated automatically and now you can make your changes.
* ArduinoIDE: Make a copy of this file and name it "my_config.h". Go to wled.h and uncomment "#define WLED_USE_MY_CONFIG" in the top of the file.
* DO NOT make changes to the "my_config_sample.h" file directly! Your changes will not be applied.
// uncomment to force the compiler to show a warning to confirm that this file is included
//#warning **** my_config.h: Settings from this file are honored ****
/* Uncomment to use your WIFI settings as defaults
//WARNING: this will hardcode these as the default even after a factory reset
#define CLIENT_SSID "Your_SSID"
#define CLIENT_PASS "Your_Password"
//#define MAX_LEDS 1500 // Maximum total LEDs. More than 1500 might create a low memory situation on ESP8266.
//#define MDNS_NAME "wled" // mDNS hostname, ie: *.local
An error accurs as well when I try
define ‘USERMOD_BATTERY’
or
-D USERMOD_BATTERY
Sorry, I’m totally lost in this.
