It’s already in the “ir-codes.h” but I can’t find a way to activate it in the Web-UI.
Somebody an idea to get it to run?
Thank you for input!
That’s exact what I thought as much.
But I always ended up with nothing works or not everything works. So I tried a many Things …
I didn’t give up
After reading the “ir.cpp” I tried “key-24 RGB” and I found out, that I have to declare the first 4 presets for the the effect Keys. I don’t know, may be the preset’s have to be set because I use a analog LED Stripe.
So what I think, is that the software checks the receiving information for translation and take’s the correct part out of the “ir_codes.h” file. For me it look’s like for use the “key-24 old RGB” key-24 RGB has to be selected. Correct me if I’m wrong!
I think, my Problem was didn’t find a hint by reading the Doku.
So for me the problem is solved for now.
Thanks for Help!
