How to set Sync disabled by default
I don’t want the sync to be enabled by default.
I have searched in all settings and in this Forum but I don’t know how to do it.
Hi @George-Verboven,
the sync-settings are in the submenu “Sync Interfaces
If you uncheck all three and click save this is disabled.
Is it this what you meant ?
Another way would be to change the port on each device - then sync does not have an effect at all.
(this is what I do normally).
Thanks Def3nder,
I unchecked all three and saved it.
But still the sync “button” seems to be enabled when power op WLED:
Sync button (on by default)
Of course it has no effect when I unchecked all three boxes, but it would be nice when there was an option to set it as Default On or OFF.
I hope Aircoookie will add this in next release
did you also uncheck the “Send notifications on direct change”? That should turn off the sync button on next reboot.
Thanks Aircoookie, that solved the “problem”
