How to set up WLED for RGB & Amber LED strips?
Hello, I have Litegear LiteRibbon Chroma 4-in-1 RGB-Amber light strips that I am controlling with the “Analog” PWM outputs of an Anthom WLED RGBCCT Analog and Digital Light Strip Controller. I have the WLED “LED Preferences” (LED 2) PWM outputs set up as “PWM RGBW” with the corresponding four PWM GPIOs mapped to the LEDs as follows: GPIO5->Red; GPIO6->Green; GPIO3->Blue; & GPIO4->Amber – in other words, the Amber LEDs are mapped to the White LEDs output. In the default Anthom configuration, all “non-white” colors use the RBG LEDs, however when I select pure white, only the amber LEDs are illuminated as expected.
Ideally, I would like to have all “non-white” colors only use the RGB LEDs, however when “cool” white is selected, only the RGB LEDs would illuminate equally, then as the white is moved towards “warm” white, the amber LEDs would gradually be blended (added) in to create an “accurate” cool-to-warm white blend.
Can anyone recommend the appropriate WLED settings to accomplish this behavior?
Thank you for your support.
