One preset is Meteor, and the other is Heartbeat. If the Meteor is switched to Heartbeat before the end of the playback, and then switched back to the process, the Meteor will not start playing from the starting point, but will continue to play from the position where it ended last time.
How can I change this and play it from the beginning every time.
Blockquote
{“0”:{},“4”:{“playlist”:{“ps”:[5],“dur”:[10],“transition”:[0],“repeat”:2,“r”:true,“end”:2},“on”:true,“n”:“list”,“ql”:“4”} ,“5”:{“n”:“心跳”,“ql”:“5”,“on”:true,“bri”:255,“transition”:0,“mainseg”:0,“seg”:[{“id”:0,“start”:0,“stop”:450,“grp”:2,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[255,8,0],[0,0,0],[0,0,0]],“fx”:100,“sx”:255,“ix”:255,“pal”:0,“sel”:true,“rev”:true,“mi”:true},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0}]},“1”:{“on”:true,“bri”:255,“transition”:0,“mainseg”:0,“seg”:[{“id”:0,“start”:0,“stop”:450,“grp”:2,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[5,126,255],[0,0,0],[0,0,0]],“fx”:10,“sx”:248,“ix”:120,“pal”:0,“sel”:true,“rev”:true,“mi”:true},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0}],“n”:“扫描”,“ql”:“1”},“2”:{“n”:“流星”,“ql”:“2”,“transition”:0,“on”:true,“bri”:255,“mainseg”:0,“seg”:[{“id”:0,“start”:0,“stop”:450,“grp”:2,“spc”:0,“of”:0,“on”:true,“frz”:false,“bri”:255,“cct”:127,“col”:[[255,111,0],[0,0,0],[0,0,0]],“fx”:76,“sx”:255,“ix”:191,“pal”:0,“sel”:true,“rev”:true,“mi”:true},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0}]}}
