Hi, I’ve noticed this problem with some effects, when I use 3 colous:
the number of leds is not calculated properly, the first colour begin to appear again before the stripes ends. To correct this I need to change the number of leds into the preset JSON and also the number of leds into the LED preferences (since the JSON can’t contain a bigger number, it’s considered the smaller between them), then I can see the right effect, but it’s mismatching other effects.
Some effects works reversely then others, is it possibiel to include/add in JSON the chance to reverse that specific effect? Thank you
