Hello,
Today I installed an Arduino Nano ESP32-S3 with WLED installation.
installation and wrapping work well. I also get the complete installation diagram.
Afterwards, the WiFi setting should appear. But here the installation goes back to the beginning. Without being able to set up the WiFi.
It is version 0.14.0
What’s going on here?
thank you in advance
Please look here for the same case with S3 Esp32-s3 devkit c - #2 by ALDIY
Thank you for your answer. But that’s not really the problem. I can do the installation via wked.instal. But once the installation is done and the logo appears with the next button. The manual describes that you press this and then enter the menu to configure the WiFi settings. But this doesn’t happen. When I press next, the initial start menu comes from wled.install. Of course, this means I cannot connect to the mobile phone via WiFi to do the further installation.
Just disconnect the Esp and repower it and look for the WLED-AP from your available wifi networks list.
That is what i am telling you for s3 do not use the site as it does not work , use esptool as you will see in the link . If you must try in site then try here also WLED installation (wled-install.github.io)
