Hi all, aktually i got different wled adapter messsages in i broker like:
State value to set for “wled.0.e8db84ddf66a.seg.0.col.2” has to be one of type “string”, “number”, “boolean” but received type “object”
If i change the data type of the data point to object or to string , both will lead into another uncorrect data type message like the above one.
Could anybody say if he has the problem also and how it could by solved ? (if it can be solved by us and perhaps needs to be solved by the developer of the iobroker adapter?!)
I recently started getting a lot of messages in the WÉLD adapter, here is an excerpt from my log:
1
1
Log-Größe: 1.5 MB
1
Zeit
debug
Nachricht
wled.0
2021-08-13 21:45:58.182 info State value to set for "wled.0.c82b9630473a.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:58.178 info State value to set for "wled.0.c82b9630473a.seg.0.col.1" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:58.173 info State value to set for "wled.0.c82b9630473a.seg.0.col.0" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:58.107 info State value to set for "wled.0.c82b9630473a._info.mac" has to be type "number" but received type "string"
wled.0
2021-08-13 21:45:58.019 info State value to set for "wled.0.c82b9630473a._info.leds.pin" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:57.155 info State value to set for "wled.0.c82b9630473a.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:57.149 info State value to set for "wled.0.c82b9630473a.seg.0.col.1" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:57.142 info State value to set for "wled.0.c82b9630473a.seg.0.col.0" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:57.064 info State value to set for "wled.0.c82b9630473a._info.mac" has to be type "number" but received type "string"
wled.0
2021-08-13 21:45:56.993 info State value to set for "wled.0.c82b9630473a._info.leds.pin" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:52.580 info State value to set for "wled.0.c82b9630473a.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:52.574 info State value to set for "wled.0.c82b9630473a.seg.0.col.1" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:52.569 info State value to set for "wled.0.c82b9630473a.seg.0.col.0" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:52.497 info State value to set for "wled.0.c82b9630473a._info.mac" has to be type "number" but received type "string"
wled.0
2021-08-13 21:45:52.412 info State value to set for "wled.0.c82b9630473a._info.leds.pin" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:19.322 info State value to set for "wled.0.c82b9630473a.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:19.318 info State value to set for "wled.0.c82b9630473a.seg.0.col.1" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:19.312 info State value to set for "wled.0.c82b9630473a.seg.0.col.0" has to be one of type "string", "number", "boolean" but received type "object"
wled.0
2021-08-13 21:45:19.237 info State value to set for "wled.0.c82b9630473a._info.mac" has to be type "number" but received type "string"
wled.0
2021-08-13 21:45:19.174 info State value to set for "wled.0.c82b9630473a._info.leds.pin" has to be one of type "string", "number", "boolean" but received type "object"
