Is it possible to activate / deactivate WLED receiving E1.31 data by integration with the home assistant?
I currently use it for the home assistant, but I have to access the wled url to activate the E1.31 reception.
Not sure I understand the question. Once enabled e1.32 is always listened for. If data is sent it uses it.
The issue is that for wled to listen it is necessary to access the page or application to enable listening and access again to disable it. I would like a way to enable and disable listening through the home assistant (switch E1.32 or similar), is there such a possibility?
Power on, power off? Or, does E1.31 turn it back on?
