Hi, in the json state and info answer from WLED are several informations. I can find the udppost under info as well as the sync state under state->udpn->recv and ->send.
But where do i find:
the udp sync group settings 1-8
the second udp port
thanks,
tom
gbd
November 27, 2022, 8:27pm
2
Hello,
Maybe use cfg.json
for info on UDP sync group settings and second UDP port? For instance:
"if":{
"sync":{
"port0":21324,"port1":65506,"recv":{ ...,"grp":1,...},"send":{...,"grp":1}
Hope this helps!
Gbd
Right ! Thanks !
Is it possible to include this in the state or info json info that comes via mqtt ?
gbd
December 5, 2022, 11:30am
4
Unfortunately, I haven’t much experience with WLED MQTT – the available api or topics to be precise.
