Hey guys,
I seen on a youtube post that WLED has some cube matrix aware settings.
Is this correct?
Or, if you are running a cube, what settings worked best, in terms of layout ect?
Hey guys,
Is this correct?
Poke at this for examples Discord
Awesome ![]()
Thank you for that!
I’m new here, and I found this project some days ago and is awesome for me old LED Cube (8x8x6), and then right now is working very well, but I want add some features more. Meanwhile I leave here my config and presets.
Config and presets:
Very nice build and excellent documentation , have you tried to use it as one big matrix
or even go further and make a funky ledmap for it
This is what I want to work out for mine. At the moment I have a segment for each panel. But its a pain to set up ![]()
Yes true , unfortunately I only made 3 side cubes ( cause it is less cost and 3 sides are only visible ) , did you experiment with something like this or other combination and only one segment
My setup for the same 3 side 8x8x8 cube is like below and works really well even without ledmap for 2d effects
So maybe I can apply to one side and to the other kinda thing.
But I dont know how to apply the files. Is there instructions somewhere?
Thanks, your Cube is very big
No yet, I’m going to try this 2D config suggestion. Thanks!
FYI: I can’t open the discord group…
You can join discord here WLED
