So i accidentally made a short circuit and now i dont know if just the power supply or everything is not working anymore.
The esp 32 seems to be working because when i visit it it doesn’t say offline.
But when i connect it to the strip, it doesn’t light up.
I would try a different GPIO pin, another strip, another esp
What do you mean a short circuit/how?
Basically the same answer as before. Try connecting the data after the first LED and see if anything lights up. If you want to test further you could skip a few LEDs and connect the data to see if they work. If they don’t then likely the strip is toast.
Where and what did you short out? How long was it shorted?
Do you have a multimeter? Check to see if your power supply is outputting voltage.
