LED's not working after reset
Newbie to wled here. I had to do a factory reset on my domestic automation controller and now, any lights I connect to it does not work. I can still access WLED ip address on that controller and I tried to make sure the settings matched my other one be that didn’t work. Thanks in advance for any advice given
Do you have the GPIO set to 2 in Led Preferences?
Yes,I do
Is the fuse on the controller blown maybe?
Checked and the fuse is fine
Contact manufacturer of your board. Settings for this board pinout might be different than WLED project defaults.
Thanks for all of the advice. Turns out my relay GPIO was cleared after the update. Set that back to 12 and everything started to work
