Hello I wanted to post here before opening a problem on github to see if anyone had any help.
I recently upgraded all of my devices to 0.14.0.
4 - Athom WLED Controllers on 0.14.0_b1 upgraded to 0.14.0 using the special ESP_02.bin.bz
1 - DomesticAutomations controller from Amazon. that I had on 0.14.0_b5 to 0.14.0 using the ESP8255.bin
I use LiveView on HomeAssistant to monitor status of my 5 WLED Controllers and it works amazingly well. Sometimes the little Athoms like to get out of whack, and I always have HomeAssistant opened on a tablet, so it helps me correct them quickly when needed.
I noticed my little Athoms quit showing live view on the DashBoard cards as I was halfway through updating. So I attempted to view the liveview directly via browser (https://192.168.xx.xx/liveview) and am faced with darkness instead of a copy of what peek is showing. Peek works just fine.
The DomesticAutomations board is 8266, and shows the live view just fine.
Prior to updating my last controller, from 0.14.0_b1 i did I live view/screenshot, and then updated it to 0.14.0 and took a screenshot, same controller. They are attached ![]()
is there anythign in a setting or accessible config that a semi smart newb can change to re-enable it/fix it? is this potentially a memory thing with the device and should spent lots of money on better? ![]()
Before Left, After Right
Thanks in advance!
