Hi all,
Have an esp8266 running WLED, however since upgrading from 0.13 to 0.14, it appears to be freezing after a couple of minutes of running perfectly.
It could be a coincidence, but feels fairly odd timing - any ideas of anything that might have changed that could be causing this?
Jinx
2
Try updating from here: https://wled-install.github.io/
The latest is also b3.
I don’t know how you updated from 13 to 14, but if it was with OTA that is likely the issue.
Anyways give that link a try and see how it goes.
Ah helpful - I thought b3 had a safety issue, so recommendation was to hold fire until upgrading.
Yes, I did OTA via Home Assistant - is that likely to cause the problem?
Jinx
4
Yes OTA can sometimes cause issues. There have been a lot of changes since 13.
Super - fixed - downgrading to 0.13 fixed all bugs, might need to wait until 0.14 stabilises…
