Locking phone with iOS app open/in background causes WLED to crash when playlist is selected
WLED has been rebooting on me sometimes when selecting a playlist. It isn’t consistent and I finally figured out how to reproduce. This is running on a QuinLED Diguno with SK6812 and White mode set to Accurate
To reproduce:
  • Open iOS app and connect to lights
  • Swipe away from WLED to put app into background
  • Lock phone
  • Unlock phone
  • Reopen WLED which is still connected to lights
  • Select Playlist (Presets seem to be fine)
This reboots WLED for me 100% of the time. If I open the app and first back out to the light selection screen and reconnect to my lights I am able to select a playlist without issue.
Side note, selecting a Playlist through HomeAssistant is also a 100% way to trigger a reboot for me, presets work fine.
Running on 0.13.0-b6 build 2112080
I opened an issue on Github but curious to see if others see the same behavior with the latest beta
This is 100% not a power issue, there are 212 SK6812 5v LED’s connected via a 18a Meanwell power supply and has been run at 100% full white for hours, these presets in the playlist are all low brightness.
Which ESP? 8266 or 32?
It’s the QuinLED-ESP32
There’s something funky going on with network calls to it. It’s now rebooting sometimes on homeassistant adjusting the brightness from an automation as well. I’ve never had issues like this with an ESP8266
get a debug build, attach serial (usb) to esp and monitor serial output from esp.
when you see a reboot copy/paste serial output.
no way to know what’s happening otherwise
Was thinking of how to log it, that makes sense. Not sure that will be possible based on the USB port orientation on the Diguno since it points right into the fuse however. Maybe I can jump it temporarily
You can just unplug ESP from dig-uno there is no need for hardware to find this kind of software bug.
Good idea, didn’t even think of it. I have it plugged in on my desk and have managed to reproduce the reboots. I need to compile a debug version now to pull the logs.
you can grab pre-compiled debug builds from @srg74
or
I just compiled and of course can’t get it to crash now. There’s a call to /presets.json every 8 seconds are so which I assume is the HA integration polling it. Here is a log from when I selected the Playlist (ID 4) from HomeAssistant and it didn’t crash.
Not-Found HTTP call:
URI: /presets.json
FileRead: /presets.json
Serialized HTTP
{"ps":4,"v":true}
Playlist unloaded.
Playlist unloaded.
Playlist loaded.
JSON buffer released. (14)
JSON buffer size: 697
JSON buffer released. (17)
Playlist unloaded.
JSON buffer released. (9)
JSON buffer size: 1713
JSON buffer released. (12)
URI: /presets.json
URI: /presets.json
Local time: 11:47
---DEBUG INFO---
Runtime: 360061
Unix time: 1643129227,061
Free heap: 185252
Wifi state: 3
State time: 0
NTP last sync: 999000000
Client IP: 192.168.1.10
Loops/sec: 3462
Max UM time[ms]: 1
URI: /presets.json
When I swipe away from WLED as I described in my steps to reproduce and reopen the app there is a call to /win which I don’t see any other time
URI: /win
API req: /win
I was able to get a locking json buffer failed message selecting a playlist through HA but WLED didn’t crash
Serialized HTTP
{"ps":4,"v":true}
Playlist unloaded.
ERROR: Locking JSON buffer failed! (14)
I saw you had a few commits related to JSON buffer that got merged since b6 got release cut. I wonder if they had an impact on the issue I was seeing? I can always try a debug build from when b6 was cut and see if the issues come back
polling for presets.json is demanding on the esp
If you are willing, testdrive my fork dev branch.
It does have some experimental mitigations for crashes.
I am able to get locking json buffer failed quite often now and the WebUI of WLED comes up Red and says connection to light failed
Playlist unloaded.
ERROR: Locking JSON buffer failed! (11)
JSON buffer released. (11)
Playlist unloaded.
Local time: 11:59
Playlist unloaded.
I have not been able to get it to crash however.
I will go checkout your fork
Locking error would usually mean concurrent requests. 11 is websocket.
Yeah I get 11 when I do it through the WLED interface but getting Locking failed on 14 when I try to select a playlist via HA every time now.
Looking in the WLED integration for HA it looks like its default scan is setup to be 10 seconds
SCAN_INTERVAL = timedelta(seconds=10)
I also have been having WLED reboot sometimes when I restart HomeAssistant and I managed to catch that crash just now
---DEBUG INFO---
Runtime: 2460484
Unix time: 1643131327,484
Free heap: 186752
Wifi state: 3
State time: 0
Loops/sec: 3122
Max UM time[ms]: 1
URI: /presets.json
JSON buffer size: 1712
CORRUPT HEAP: Bad head at 0x3ffdd008. Expected 0xabba1234 got 0x3ffdd108
assertion "head != NULL" failed: file "/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/heap/multi_heap_poisoning.c", line 214, function: multi_heap_free
abort() was called at PC 0x40158407 on core 0
ets Jul 29 2019 12:21:46
rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:8896
load:0x40080400,len:5816
entry 0x400806ac
---WLED 0.13.0-b6 2112080 INIT---
esp32 v3.2.3-14-gd3e562907
heap 277476
Registering usermods ...
Reading config
Reading settings from /wsec.json...
JSON buffer released. (3)
Reading settings from /cfg.json...
Removing all.
Successfully inited strip 0 (len 104) with type 30 and pins 3,255 (itype 20)
Successfully inited strip 1 (len 108) with type 30 and pins 16,255 (itype 20)
Starting usermod config.
JSON buffer released. (1)
Initializing strip
Playlist unloaded.
Usermods setup
Access point disabled.
Connecting to Making Wifi Great Again...
Local time: 01:28
Connected! IP address: 192.168.1.10
Init STA interfaces
mDNS started
14 is regular HTTP /json request.
Corrupt heap (after a buffer release) means some incorrect memory allocations happened.
17 would be JSON handling. so somewhere in web server callback.
but FileRead /presets.json gets me baffled
it shouldn’t be there
that’s often!
This is using your dev branch, I got it to crash by selecting playlists through the WLED web interface
Apply preset JSON buffer requested.
Deserializing state
Playlist unloaded.
WS JSON send buffer requested.
JSON buffer size: 1783 for WS request.
Sending WS data assertion "inconsistent oversize vs. space" failed: file "/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/lwip/lwip/src/core/tcp_out.c", line 473, function: tcp_write
abort() was called at PC 0x40158f67 on core 0
Backtrace: 0x4008e20c:0x3ffb6160 0x4008e43d:0x3ffb6180 0x40158f67:0x3ffb61a0 0x401793a7:0x3ffb61d0 0x4010d85b:0x3ffb6240 0x4016c740:0x3ffb6260 0x4008a955:0x3ffb6290
Rebooting...
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400806ac
---WLED 0.13.1-bl6 2201231 INIT---
heap 272388
Reading config
Removing all.
Initializing strip
Usermods setup
lastReconnectAttempt == 0
Access point disabled (init).
Deserializing state
Playlist unloaded.
Local time: 01:28
Init STA interfaces
mDNS started
Sending WS data to a single client.
WS client connected.
WS JSON receive buffer requested.
URI: /presets.json
JSON buffer size: 1782 for request: 3
URI: /presets.json
And heres a crash that just happened adjusting the brightness slider in HA
Deserializing state
JSON buffer size: 717 for request: 1
CORRUPT HEAP: multi_heap.c:187 detected at 0x3ffd80c0
abort() was called at PC 0x4008d3de on core 1
Backtrace: 0x4008e20c:0x3ffda070 0x4008e43d:0x3ffda090 0x4008d3de:0x3ffda0b0 0x4008d98d:0x3ffda0d0 0x4008de8a:0x3ffda0f0 0x4008596a:0x3ffda110 0x40086141:0x3ffda130 0x4000bec7:0x3ffda150 0x4018d249:0x3ffda170 0x40111bd9:0x3ffda190 0x4019dee3:0x3ffda1b0 0x40112b57:0x3ffda1d0 0x40112b99:0x3ffda1f0 0x401132d2:0x3ffda210 0x4011330d:0x3ffda240 0x4010dce9:0x3ffda260 0x4010de6c:0x3ffda290 0x4010e445:0x3ffda2b0 0x4008a955:0x3ffda2e0
Rebooting...
entry 0x400806ac
heap 277380
Reading config
Removing all.
Initializing strip
Usermods setup
Deserializing state
Playlist unloaded.
Local time: 01:28
Also interesting that my playlists are no longer working at all with any build past the b6 release cut, they load the first preset but never go to the next. I think its time to go back to bed :stuck_out_tongue:
