Hey there, running a d1 knock off, 375 led setup.
the whole thing runs smoothly, can have it on for hrs at a time without issues.
in the web interface if i choose Power off and come back to it later/next day/few hrs. i have to reboot the d1 to get the connection to establish.
ive turned off wifi sleep in settings and it has a static ip . no other connection issues in the home with many wifi devices, jsut this one needs rebooting before it will connect again.
any idea what to check out?
thanks
Do you have a relay connected to the D1 Mini, perhaps to the relay output pin, passing power to the D1 Mini through a relay contact?
Is the D1 mini LED on / blinking in the power off mode?
Are you running 0.12 ß build @Aircoookie posted this past weekend? If not, I recommend giving it a try.
And just so we know, what firmware version is running when this problem happens? You can look at the info screen to see the relative wifi signal level.
I recommend monitoring it while the d1 Mini right before and right after the power off command is given. Compare the wifi signal strength. The might vary a small amount, but should not change much. if it changes more than a few dB, that’s a problem - at least to me.
