Describe the bug
My wemos d1 mini (I think it’s a knockoff) will connect to wifi with the firmware just fine but then it goes offline. It stays offline until I reboot it. Then it goes online for another 1 minute and then it dies again. I have already seen some people with a similar issue which is #424 I seem to have tried everything on that issue list (including building my own firmware and doing the ping fix) with no success. I have tried to compile different versions and older versions and nothing seems to work. I have my esp in a box outside running some fancy Christmas lights but it does the same thing when it is in my room right next to my router. I just wanted to see if anyone else has this problem and if anyone can help me out.
To Reproduce
I connect to the access point, I get it on my network (I have an amplifi instant wifi network if it matters) Then it boots up and goes offline after about 30s to 1 min. Then if I power-cycle the board. It goes back online and repeats the process.
Expected behavior
I expect it to boot up and stay online
WLED version
- Board: [D1 mini]
- Version [A bunch but I have been working with 10.0.2 and 0.11.0 (the newest one)]
- Format [I have used bin files and compiled by myself using platformio and it makes no difference.]
Thanks to anyone with any ideas!
Edit: the connection to my network is not faulty, the webpage just goes down
(this is copied straight from github)
