Hey there! I am using a D1 mini and I have it flashed seemingly successfully. I can set all the LED preferences and the strip works perfectly.
However, I am having trouble getting the D1 to connect and show up in the wled app! I seem to be able to enter the SSID and password correctly and then it shows up with a created IP address in the Client IP area. I have tried a static IP as well.
When I go to the wled app and try discovery, no dice. I try to manually add, no dice. Discovery never discovers and adding manually shows device offline. The 2.4 and 5ghz bands are enabled, I believe with the same SSID. Would it be having trouble auto routing wled devices and such?
Let me know if I can give any more info to help! I tried reading through some of the github issues and issues posted here.
