LSC Smart Connect LED strip (10 meter, 24V, RGBIC+CCT)
Hello, I need help with my led light strip. I am starting to get pissed off
After cutting my led light strip, half of strips dont work anymore; no power supply.
my question is, I wanted to buy L shape for my corner to make it look cleaner it looks really
crooked and not cuter the wall looks all messed up. up
I use Smart LSC connect for 10M with 24 volts. What I have is 220-240V AC 50/60 Hz 24V DC 24 W
RGBIC +CCTIC {2700-6500K
LUMIN IS 1400 MAX WIFI IS 2.4GHZ this is all the information I can give i hope this is enough detail to look for what type of connector I need without needing solder i hope someone will reply quickly, please. I didn’t just want an L-shaped corner connector i wanted a connector too. I wanted to test out what works i got 4 pin
Generally all of those crimp on LED connectors are junk. They very often don’t work and make poor connections. You really are better off soldering them.
thanks for the reply and warning i was about to go crazy. Then I will bring this strip to my work he will solder my strip since i have no experience with it i need to learn it
