Hello Wled community!
Is there a way to use a macro (button) to start Wled BUT with a 3.3V (high) input instead of low input (ground)
Set up :
I start Wled with home assistant AND with a switch. The switch control an 5V AC/DC converter for LED and a relay. It grounds the GPIO links to the macro and start WLED.
It works BUT i would like to remove the relay and start WLED with a high status instead.
Is it possible?
thks and sorry for my english ![]()
When you define the pushbutton under Config->LED Preferences->Hardware Setup,
Choose “Push Inverted” for the type of button/switch.
Thks,
I Will try back to home!
