Minimal latency between audio signal and light responce
which WLED build could provide a minimal latency between input audio signal and light responce in FFT frequency reactive mode? I mean the fastest FFT processing, so that the user does not notice any delays between the melody and the light response.
hi @mediotex this is maybe related to your used Hardware
some hardware may produce a latency lower then 10ms while others ate up to 1sec
so changing the input hardware will make a difference
