More then 10 segments save on slot 16
Hello,
Im using WLED to make a library with 14 boxes with led lights inside also got PIR detection to all of the boxes and im using segments to make every box light up different effect. I found a thread here how to make the segments more in my case 14, but when i save it to slot 16 after reboot only shows 10 segments. Do i need to change anything else in the code to get it work, and is it possible to do this.
Best Regards :slight_smile:
I believe that’s a memory limitation.
Yes i guess to, but can i change it somehow or is not a great idea ?
No, there is not enough memory, so we need to wait until wled moves to a file system.
I see well i will get it thru some little battery to avoid unexpected resets till then :D. Thank you
