Hi all!
My daughter and I want to install a LED setup in her room. Is my thinking correct or am I missing something important? Use case and question at bottom, I want to share my thoughts about hardware first.
The setup will consist of three LED bars, arranged in U form, on left and right wall as well as the front wall (viewed from desk) → “center”.
The sides are ~330cm each, the front ~260cm. Total of ~920cm.
The side’s first LEDs are both at the center.
We want to use “BTF-LIGHTING RGBW RGBWW SK6812” 5V 60 LEDs/m, from which I still have a 5m roll left over.
The strip shall be placed in a 45° alu profile, along the top wall corners.
I want to power it with two 5V12A transformers, and wire it with 24AWG. I hope to be able to use the aluminum profiles for the cabling.
Operated by two or three or four ESP32+relay.
Power is divided at the relays, injected at both ends of the three led strips.
Would mid-injection work better?
Planned usage:
Simple light ( for improved wife-acceptance-factor
Audio visualization w/ LEDfx:
Both sides display an spectrometer like effect, while the front strobes to the beat. The sides should go synchronously.
I think the best solution for this special case would be to connect the side strips to the same PIN?
Ambient lighting with effect.
Kids, right?
We want to be able to show a non-audio effect going seamless through the room, e.G. a wipe from back-left over front to back-right, as well as e.G. rainbow going synchronized on the sides, while audio-reactive-strobe on the center.
Ambient light for the display.
On my workstation, I have a hyperion running. I would do something like this, but with a lot fewer but larger grabbing zones. Mixing this with audio-reactiveness could also be cool, like the sides are hyperion, the center is LEDfx.
Setup:
I plan to play around with the following setups:
One ESP (One pin per strip/sides on one PIN and front on another):
WLED-Effects should work best
LEDfx cannot distinguish between the three strips
Two ESP (Front on one ESP, Sides on one ESP(same pin/two pins))
LEDfx can distinguish the side strips, unless on same pin
WLED effects still seamless?
Two ESP plus orchestrator (Front on one ESP, Sides on one ESP(same pin/two pins), one dedicated controller/orchestrator)
same as above, but one additional ESP has both ESPs as DDP RBG-
I am losing the warmwhite LED
Three ESP (left/right/center)
WLED effects
LEDfx
Three ESP + orchestrator
WLED effects over orchestrator -
LEDfx directly on lights
wifi “traffic jam” when all ESPs are too close together
The three plus one solution might also give the possibility of integrating Alexa voice commands as well as a physical switch.
Any recommendations from experienced users?
