Been working on this PCB for while now with the helps from @Jinx and @srg74 on the logic shifter. I made a few version based on the different type of logic shifter but end up I settle with TXS0108E. Finally I got it done and sent it to make the PCB. Will update this once I get it.
It finally arrived. It so beautiful to look at. Hope it works. 2 already been sold once the final testing is done. Hope you guys like it.
(upload://6h1sulmkxs3OagPuhxhs8zfvyi4.jpeg)
I like your board layout, im having trouble following ground on it. But that could be me. Is the idea here to run just the data lines , driving them from 3.3 to 5 volt trough the shifter into the jacks and not run power through them (would be a heavy load if you did)
I see the capacitor, that should smooth out the input voltages, but i thought.the resistors were optional once a shifter was in place (at least if you r driving 5v 8211b’s)
Your layout is similar to what ive been breadboarding, except ive been powering my rig through a 110ac ac to 5v dc buck convertor, and feeding a relay to switch on power supply.
Nice work there. What program is used to build the custom pc board ?
Here how the board would look like when it finished. Hopefully everything going well. Thanks
