Hi, i am unsure about the “Make this instance discoverable” under sync settings - what is the sense with this option and in which cases it is better to switch it on or off ? I only find out that they are listed under “nodes”.
Thanks,
Tom
Thanks,
Tom
Thanks Tony, but this describes the sync function which is great and i use it already. My question was concerning the option “Make this instance discoverable”…
Only if you want WLED instances know of each other so you can navigate between each of them without leaving WLED UI.
No other benefits or drawbacks.
