I have a 2M (30 LEDs/M) WS2812B that is giving me headaches. Only the first 1 or 2 LEDS will light up when connected to my Wemos D1 Mini’s. I have tested the strip with 4 D1 Mini’s. I can plug in other strips to those D1 Mini’s and the other strips works as expected. It is just this one strip. I have tried to troubleshoot and below are my tests, but can’t make sense of my results.
Troubleshooting Tests: LED Preferences set to 60 LEDs.
Strip does not work with 4 different D1 Mini’s (Shows 1 white LED. sometimes 2nd LED different color)
Strip will work if I power up D1 Mini first and then plug in the strip
Strip will work if I daisy chain it as the 2nd strip. First strip is a 156 LED strip. (LED preferences set to 216 LEDS)
Strip works with SP002E USB connector
Strip works with ESP32 DEVKITV1 with WLED
Strip works on Lolin NODEMCU v3 with WLED
