Hi all. I got a BTF Lighting single-color WS2811 IC LED strip. 360 LEDs/m; 1800 LEDs total; 60 IC chips. I need to define two, equal length segments. The first segment works well. All LEDs light up. The second segment has gaps. I’m using a 24V, 5A power supply. I limited the strip to 4A max in the config. Example of the LEDs and my segment config attached.
If you have 60 IC chips than your segments should be 30 pixels each.
