hi @TokyoDave
The product is internatianal and most use “BARE Electric paint” its on amazon Japan Tokyo available for 6200 Y its painted like normal paint on all Surfaces and will give you a 1Amp at 1mm With
they also got PEN like Containers so freehand wiring is possible but i recomend masking for the WS2812
by masking i woudt go for the pads 2x4mm sideways the 1mm wire as most 10mm long for better mask
then use a Simple thin paintbrush to finish them up
TIMEi to keep the LED Stick is different in Temp and Version of stickness see product details
Thanks @Magig_Wled for looking it up, and for the usage tips. Amazon says it is acrylic based, probably acrylic gel doped up with loads of carbon powder.
Here is first presentable version of Polar Radial Chase effect, running Random Cycle palette.
Notes: Polar rho is used to select the Fg chase color from the palette. Theta selects the Bg color, and its brightness is set by rho, so that the Bg dims towards the center.
Very impressive.
The configuration for my usermod is ‘30,24,18,12,6’ (the number of leds in each ring. That’s all. And with only that configurable information, I easily wrote the effect which sets the color depending on direction (radial rainbow), sets the brightness depending on distance from the center, etc. That together with palette choice is quite powerful.
If you can show me how you can easily do this without the software knowing the geometry, you are a magician. I’m sure you can approximate some of it by human ingenuity, of which you have lots :).
I’ll probably make a bigger disk, and simply configure the ring counts, and everything will work. And I have other geometries I will probably tackle.
To each his taste.
as i sugested aove its only the led mapping and then segmentation on this count
ledmap1.json
{"map":[0,30,54,72,84,5,34,57,74,85,10,38,60,76,86,15,42,63,78,87,20,46,66,80,88,25,50,69,82,89,1,2,3,4,6,7,8,9,11,12,13,14,16,17,18,19,21,22,23,24,26,27,28,29,31,32,33,35,36,37,39,40,41,43,44,45,47,48,49,51,52,53,55,56,58,59,61,62,64,65,67,68,70,71,73,75,77,79,81,83,90]}
ledmap2.json
{"map":[
0,30,54,72,84,
10,38,60,76,86,
20,46,66,80,88,
5,34,57,74,85,
15,42,63,78,87,
25,50,69,82,89,
1,2,3,4,6,7,8,9,11,12,13,14,16,17,18,19,21,22,23,24,26,27,28,29,31,33,35,37,39,41,43,45,47,49,51,53,55,56,58,59,61,62,64,65,67,68,70,71,73,75,77,79,81,83,
32,36,40,44,48,52,90]}
