PlatformIO suddenly won't build binaries? (Builds, no errors, but none produced.)
A few days ago, things were building just fine. Suddenly, it stopped producing binaries, even though it reported SUCCESS. Clean/Clean All/Build/etc. did not make it start again.
I have removed and reinstalled all the VS Code plugins several times, with various different results. Twice it’s made a binary, but the rest of the time it just says it did but makes nothing. Very odd. I don’t know what broke, but I wanted to post this here to see if others have encountered it.
I did find it would create the generic .bin but not copy it over to the build_output, which makes it seem like scripts are just not running at the end.
Anyone had this happen? I haven’t been able to consistently make new builds in about four days now.
This issue remains – it will work for awhile, then stop, then start working again. It seems it’s not running the final scripts, but I cannot figure out what is going on to cause it to break, or start working again.
Using macOS, Visual Studio Code, latest WLED retrieved from WLED.
I am hoping for a pointer on where to look for logs or something showing what the failure is.
Can someone explain this? I followed through the code to figure out it ends up at “output_bins.py”
I decided to print some print() calls in the script. When I do, I get my binaries again:
def bin_rename_copy(source, target, env):
    print("bin_rename_copy")
and
def bin_gzip(source, target, env):
    print("bin_gzip")
Boom. Build makes the .bin file.
So I took out the two print() calls.
And now it does not.
Computers, amirite?
I had the same problem…hours of trying different stuff…
I followed your example, but only added:
print(“bin_rename_copy”)
and esp32dev.bin, esp32dev.bin.gz, WLED_0.14.0_ESP32.bin
suddenly appeared on the next build.
Please make it make sense…please…
Hello,
I’m facing the same issue too!
sometimes even if the build task compiles successfully the “build_output” folder is EMPTY!
I thied to run the “full clean” task, removing the “.pio” folder but any af these steps fix the issue.
What should I do?
