Hi everyone,
I’m using WLED on a WT32-ETH01 with the official version 0.15.1, and I’ve set up the following preset configuration:
"0": {},
"1": {
"on": false,
"bri": 20,
"transition": 10,
"mainseg": 0,
"seg": [
"id": 0,
"start": 0,
"stop": 54,
"on": false,
"bri": 255,
"fx": 0,
"sx": 240,
"ix": 100,
"pal": 0,
"rev": false,
"n": "Segment 1"
"id": 1,
"start": 54,
"stop": 108,
"on": false,
"bri": 255,
"fx": 0,
"sx": 240,
"ix": 100,
"pal": 0,
"rev": true,
"n": "Segment 2"
"n": "Init"
"2": {
"on": true,
"seg": [
{ "id": 0, "on": true, "fx": 98, "sx": 3, "ix": 100, "pal": 0 },
{ "id": 1, "on": true, "fx": 98, "sx": 3, "ix": 100, "pal": 0 }
"n": "All on"
"10": {
"on": true,
"seg": [{ "id": 0, "on": true, "fx": 98, "sx": 3, "ix": 100, "pal": 0 }],
"n": "Seg1 on"
"20": {
"on": true,
"seg": [{ "id": 1, "on": true, "fx": 98, "sx": 3, "ix": 100, "pal": 0 }],
"n": "Seg2 on"
"30": { "bri": 255, "n": "Brightness Day" },
"31": { "bri": 20, "n": "Brightness Night" },
"3": {
"on": false,
"seg": [
{ "id": 0, "on": false, "fx": 0 },
{ "id": 1, "on": false, "fx": 0 }
"n": "All off"
"11": {
"seg": [{ "id": 0, "on": false, "fx": 0 }],
"n": "Seg1 off"
"21": {
"seg": [{ "id": 1, "on": false, "fx": 0 }],
"n": "Seg2 off"
I’m facing two issues I can’t seem to resolve:
1. Segment Activation Behavior
After startup (via the “Init” preset) or after using “All off”, when I activate Segment 1 using the “Seg1 on” preset, Segment 2 also turns on, even though it’s not included in the preset.
However, if I first turn off both segments using “Seg1 off” and “Seg2 off”, and then activate “Seg1 on”, only Segment 1 turns on, as expected.
Why does Segment 2 get activated in the first scenario? Is there something wrong with how the presets are structured?
2. Brightness Change Restarts Effect
When I change the master brightness via the GUI or using the “Brightness Day”/“Brightness Night” presets, the effect restarts. I would prefer to only adjust brightness or color globally without restarting the running effect.
Is there a way to change brightness without triggering a full effect reset?
My goal is to have both segments operate independently, unless I explicitly use the “All on” or “All off” presets. Any help or suggestions on how to fix these behaviors in the preset configuration would be greatly appreciated!
Thanks in advance!
