Hello,
I’m not familiar with wled yet and would need a little help to understand if it’s possible to edit the default syntax for the following idea?
I am thinking about installing a 5m sk6812 around a through stip. The through stip is to be split into 3 logical effect parts top, left and right. The effect is a double scanner (effect 60). I want the effect for each part, top, left and right, so separate. Is that possible?
The current syntax of the preset is as shown here for the top part (2/3), starting at led 75 to 225.
How can I edit the syntax for the left vertical part (1/3) from led 0 to 74 and the right vertical part (3/3) from led 226 to 300?
{“on”:true,“bri”:210,“transition”:7,“mainseg”:0,“seg”:[{“id”:0,“start”:75,“stop”:225,“grp”:1,“spc”:0,“of”:0,“on”:true,“bri”:255,“cct”:127,“col”:[[255,0,0],[0,0,0],[0,0,0]],“fx”:60,“sx”:104,“ix”:244,“pal”:2,“sel”:true,“rev”:false,“mi”:false},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0},{“stop”:0}]}
Thanks for your help,
JohnnyB
Translated with DeepL Translate: The world's most accurate translator (free version)
