Presets in SmartThings and/or SharpTools
Has anyone managed to get WLED Profiles to trigger from a SmartThings automation or SharpTools Rule? I can’t seem to figure it out.
I have a WLED device added to SmartThings with an Edge driver. The light itself works fine, I can turn it on and off manually as well as start a preset manually. But I’m not able to do so from a routine or automation. I also tried to get it to work from SharpTools, which does expose a setPreset() method, but I don’t know what to pass it to get the preset to run.
Any ideas?
You pass in the preset ID (0, 1, 2, 3, etc) as a value into the setPreset() method.
