I now tried it on a new ESP32 but that doesn’t seem the issue. Also the Config seems fine working. The last idea is, that it is related to the presets itself. I added the API command for an “corrupted” Preset. I noticed that some will load even with different segments contained but the majority will not load.
{"on":true,"bri":255,"transition":7,"mainseg":0,"seg":[{"id":0,"start":0,"stop":15,"grp":1,"spc":0,"of":0,"on":true,"frz":false,"bri":255,"cct":127,"set":0,"n":"Links","col":[[116,255,10],[0,0,0],[0,0,0]],"fx":67,"sx":66,"ix":128,"pal":46,"c1":128,"c2":128,"c3":16,"sel":true,"rev":false,"mi":false,"o1":false,"o2":false,"o3":false,"si":0,"m12":0},{"id":1,"start":15,"stop":49,"grp":1,"spc":0,"of":0,"on":true,"frz":false,"bri":255,"cct":127,"set":0,"n":"Mitte","col":[[116,255,10],[0,0,0],[0,0,0]],"fx":67,"sx":66,"ix":128,"pal":46,"c1":128,"c2":128,"c3":16,"sel":true,"rev":true,"mi":true,"o1":false,"o2":false,"o3":false,"si":0,"m12":0},{"id":2,"start":49,"stop":65,"grp":1,"spc":0,"of":0,"on":true,"frz":false,"bri":255,"cct":127,"set":0,"n":"Rechts","col":[[116,255,10],[0,0,0],[0,0,0]],"fx":67,"sx":66,"ix":128,"pal":46,"c1":128,"c2":128,"c3":16,"sel":true,"rev":true,"mi":false,"o1":false,"o2":false,"o3":false,"si":0,"m12":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0},{"stop":0}]}
