If I’m trying to change a set of LED’s.
Do i turn on the MCU send the config file, power cycle then the presets? Does it matter?
Can I do config and presets then power cycle at the end? Any other tips?
It seems like sometimes when I do this my config settings get hosed.
What version are you running?
0.13.3 addressed some issues.
Looks like V 0.14.0-b1 is imminent with a whack of (nice) new features…
I am on 0.13.3. One particular bug I am seeing, is sometimes when I flash a new board everything works fine but the LED’s are in powered off state on start, no matter what the settings bit is set to or if the playlist tells it to turn on.
What are you using to flash your boards?
copying config and presets to new boards over wifi
Any insight into this,
“ Restoring presets/configuration will OVERWRITE your current presets/configuration.
Incorrect configuration may require a factory reset or re-flashing of your ESP.”
That’s just a warning to make sure you want to do it.
