Ready to use ESP32Board?
Hi everyone is shifting to a ESP32 also in DEV most Requirerd
That brings low Electronic People to a Big Problem soldering More PCB powerarangment AND AND …
Q: Is there a Out of the Box Board with ESP32 that fits the requirerments of WLED usige on WS2811 5V
Requirerments :
12V input Chinch 5.5-2.1mm PLUG
driving 5V out <1A Powersuply for at least 200Pixel Min Brightness
Logic outPin that can handle the 5V/12V Strio so NO Levelshifter or Periferie needed
MY Low Cost 2,5USD WEMOS //Clones ESP8266 can do this all on the Board can do this out oif the BOX and will be out of development Soon
AS all understand very good Technic goes on and up not Back THIS is FINE
Make it Easy not more complecated and Cost Time entensive
Thanks for Review
Which board are you using that is $2.50 including the power connections/regulation and level shifter?!
@kilrah im curently using 99% the Displays i make this Board
https://de.aliexpress.com/item/32465582843.html
Board has many IDENT
WeMos D1 WiFi UNO R3 BASED ESP8266 ESP-12E ESP-12F
OK so just an Uno shaped board, no levelshifter… they make the same with an ESP32 for almost the same price
https://www.aliexpress.com/item/1005006140622416.html
Just ordered some of these, they are costing about $10 each assembled.
I have been messing with making my own PCBs but this is far beyond me.
I already have the Mini ESP32 boards to plug into it, it’s going to interesting as to how well they work.
Edit to Add: - watch out with the premade ESP32 boards, I have found that a number of the ESP32 boards have the rows of pins at a different distance, hence I went for the mini version that seems to standardised.
just ordered one of these to try out
inc postage it was £4
