Hi all,
I’m looking for a simple “static” effect to be controlled remotely via HomeAssistant or any other external remote.
What I need:
Set a static light spot on the strip with
- Color
- Brightnes
- Position
- Blur
Perfect would be to have a configurable portamento to set the time needed for the spot to glide from one position on the strip to a new one.
Use case:
I want to create a vertical light strip for a spiral staircase that can smoothly adapt the light hotspot according to the stair level that will be triggered by several motion detectors
Until now, after some research, I did not find any sollution for my use case.
As I’m pretty new to WLED I’m sure, that there might be a solution for my demand that I’ve just missed.
Is there anyone with a hint or clue how to solve this?
Thank you for your support!
best regards
Stephan
