In Config>Time & Macros>Time-controlled presets
I have created 2 playlists. One that plays the lights I want. I have this under “Sunset” with the minutes set to -5. This turns on as desired. Every evening, 5 minutes before sunset. My second preset is just to turn everything off. I have created a preset with nothing on, and saved it. If I select it manually, it works as desired. When I put it under sunrise, or if I set one of the other time slots to something like 23:30, it does not do anything. What am I missing. If I don’t go in and select the “off” preset manually, the lights run 24 hours.
