This is my first time with any LED controllers and set the wifi without writing down the mDNS or changing it. Is there a way to factory reset it without accessing the web portal/app? I have a domestic automation vegas lights LED controller.
You should be able to hold down GPIO0 for 30s to factory default if it’s a reasonably recent version of WLED.
I would run a jumper from the pin labelled GPIO0 to GND.
Reading through other docs, 30s might be more than you need (but shouldn’t hurt).
