Slowest effect speed is not slow enough
Hi everyone,
I have already tried in several topics to find out how I can reduce the speed of the effects even further.
Personally, I prefer quieter movements of the light.
The Fireflicker2012 effect in particular is too restless for me.
Is there a simple solution to make such effects play super slowly?
Best regards
Timo
While we try to use that to make the effects FPS faster but since you said you want simple solution ( the other being hack the code ) go under led preference and change the FPS , some effects might cooperate better then others
thank you for your quick response! :slight_smile:
I will try that later and come back to you.
In case I want to “hack the code”: How does it work? Where in the code do I have to make changes?
Source is here GitHub - Aircoookie/WLED: Control WS2812B and many more types of digital RGB LEDs with an ESP8266 or ESP32 over WiFi!
The adjustment of the FPS has definitely brought about a change. Unfortunately, the visual reproduction of the Fire2012 effect is somewhat limited, as the effect “hangs” a little.
I will try adjusting the code soon.
Yeah low fps will result in bad effects in most cases . Nothing better then adjusting the code the way you like .
