@nismos14 @huggy-d1 @way2fast4u
Guys, this is a very basic device handler. My goal was to simply integrate wled into ST so that I can turn it on/off - change color/brightness via Google Home. There is nothing fancy, and I coded absolutely nothing around presets and effects. I also exclusively use Home Assistant as my frontend home automation UI, and stay as far as possible from the ST app!
But as it stands, just re-tested in the ST app, with the 0.10 WLED: ST will turn on/off, change color/brightness, and will also when off turn on using last settings (if it was green at 50% it will turn back on green 50%). I have no idea what will happen when effects are used, I personally don’t use them and didn’t feel the needs to integrate them.
