Smooth transition between presets
i am new to Wled and i use its latest version. I cannot find a way to have smooth transitions from one preset to another in the playlists i create.I have tried setting long transitions( like 10 seconds) in the playlist settings, then also tried with the led configuration settings, but nothing happens. Generally, i use slow motives for ambient lighting, and the sudden transitions from one theme to the other hurts the flow badly. Does anyone know a way to fix this ? Thanx.
Transitions don’t yet work on effects. Just color/brightness.
Thank you for your reply. It’s a shame transitions don’t work yet with effects. But since you say “yet” , do you have or anyone else any idea when that will be possible happening in WLED ?
It is very difficult to implement correctly.
Also ESP8266 may not have enough resources to do it properly.
It is on the roadmap, though.
Thank you for your reply. Apart from ESP8266 I use ESP32 devkit 1 that seem to handle data better in general. Can’t wait for smooth transitions!
