Soldering LED-Ring
i’m not that good in soldering - here’s my question:
soldering LED-Rings is pretty hard as the solder joints are small and very close to each other - you also need to optimally solder 2 wires on one jolder joint and the signal wire is crossing the other 2 wires …
is there a trick / soldering aid for soldering those?
i’m thinking of a small part which first gets solderd and then provides more space for soldering 2 wires … any ideas if something exists?
Hi ,
I am also not a fan of soldering small parts or smd because I have a poor eyesight .
One time I have taken a board to an electronic repair place to solder two really tiny
smd and they did it for me for free . Hopes this help
