Yes, I know. If I’m not wrong, they have not a community forum, and also people that are developing SR WLED are here on this community, that’s why I’m writing here
Some update after lot of tests:
I have tried three different ICS-43434MIC and 2 new INMP441 modules. Ultimately, the ICS-43434 is not a working microphone - all the ones I’ve tried only produce noise. On the same PCB with the same firmware and the same settings, the INMP411s work correctly.
This is not really good news nor a solution , as i seen some of this discussion on SR discord might be no need to go over the details again , still it would be best if you verify those ICS-43434 mics with bare esp32 as the same mic is mentioned on sr wiki to be working well .
If you already verified that three ICS-43434 do not work with SR 13.2 or 14 beta on bare esp32 then please post a link to the source you got those ICS-43434 mics from so we could check with the seller . if you have a faulty mics as you suspect then I hope your first step is to file for a return
Yes. I did it. I wired the MIC to the ESP32 devkit. I tried 3 of them alternating with INMP441 without changing any config and also reading signals with the oscilloscopes to be sure thath the wiring was good.
I bought them from Digikey, it is a certified distributor.
We were planning to order some ICS-43434 for testing only based on the wiki
but if you got an issues with bare esp32 then we might hold on that for a while .
we only used INMP441s as we could not find any readily available ICS-43434 on Alie .
