I’ve been struggling for a while now but I can’t get over it.
I want to have a strip toggle every time the touch sensor (KY-036) is touched. I’ve already tried a lot more I like but can’t figure it out.
Can someone help me step by step.
Setup Button 0 with the GPIO of our switch, create a toggle preset (T=2) go to Time & Macros page, Button Actions section, enter that preset number for Button 0 short press.
That also does not work when I touch the touch sensor, my eps8266 mini loses its internet connection and the color keeps changing.
Then something is very wrong. Post what you have.
I have the following hardware:
The LED strip itself works, but if I want to turn it on and off with that touch sensor, the WiFi disconnect.
Is this all you need to know?
If that sensor puts out 5v, I don’t think it will work. The device needs to pull the GPIO pin to ground. You may need to add a transistor in between.
Thank you for your time. I have found a other way to do it.
