Total LEDs doesn't match LED outputs: 1 + 2
I have 2 strings running from a center point out each direction.
  • String 1: 0 - 363 and Reversed
  • String 2: 363 - 592
The [Total LEDs] shows 955 and I can’t change it.
I also can’t change the [Start:] of either string.
Did I set something up wrong?
v0.13.3 “Toki” build: 2208222
esp32 v3.3.6-16
You don’t set the count in Total LEDs anymore. It’s done in the Length parameter for each output.
Yeah my bad. It’s Start and Length as values and not Start and End
