UDP does not work with group leds
When I group LEDs, this works only for the effects in Wled. But when I stream data via udp, it doesn’t show leds in groups. Can you fix the led group with udp?
at the moment segments and thus grouping only works with WLED effects. External sources, both E1.31 and UDP, just output directly to the LEDs and bypass segments. I agree that grouping for external sources would be nice to have, so I’ll look into it.
This would be a solution to my problem/project. I am designing a upright standing LED tube for show/stage usage. Therefore the WLED-Project is quite perfect with all the internal FX and the different DMX-Modes. My first design contains 120 LEDs. But without Grouping (120/6=20 groups x 3 Channels => 60 DMX/ArtNet Adresses) i get way to much Adresses. Now i use a Stripe with only 30 LEDs/m.
With the new MAESTRO DMX (AI DMX controller) i have to drive all the pixels/groups as a single LED. So the grouping also for DMX/ArtNet would be great.
ChatGPT recommends to make a User-Mod, but i’m not able to get this done.
