Uncorect color
Hi, I have this problem that the colours on the ribbon do not match what they should be. When the ribbon is supposed to light pure red there are other colours.
It should just be red.
hi @gamemaster6181
Please set a Preset of all Nodes in the first segment STORE this
zhen work with the second Preset this may give you a bettr result
the Default that is loaded is notr a Preset that is sopost to work with
WE need more info on your system to get a better answer
What have you configured for the LED type on Config->LED Preferences?
What type of LEDs do you have?
If you change it, you only change the position of the colours on the ribbon.
I’m using nodemcu esp8266 and ws2812b
set the type to WS28xx RGB then and not SK6812 RGBW
